Engine Size
Old Apr 15, 2006 | 06:56 PM
Asobu's Avatar
Default Engine Size
What is the biggest and best engine to fit into a 96 honda accord lx two door coupe?
Old Apr 15, 2006 | 08:37 PM
lightshow's Avatar
Default RE: Engine Size
h22a1
Old Apr 15, 2006 | 09:19 PM
Asobu's Avatar
Thanks for the prompt reply. I was looking around for one of these engines and I found this one http://cgi.ebay.com/ebaymotors/JDM-H...spagenameZWDVW it has less than 40k miles on it. Also would the manual transmission bolt up to this one or would I need to get another transmission as well? And would I need new motor mounts and all of that jazz? Thank you
Old Apr 15, 2006 | 09:39 PM
lightshow's Avatar
no i wouldnt get that one because its just the engine. its better to get a setup with the engine tranmission ecu wiring harness and axles. your current transmission will work with the engine but it wont work well unless you turbo
Old Apr 15, 2006 | 10:45 PM
Hi Asobu..welcome to the members forums, I would like to put in a picture of the ideal engine to put into that Honda of yours so here she is, hope you like the looks.
[IMG]local://upfiles/22/6005781F9A4840E6AEE2C1278CDEC3E4.jpg[/IMG]
Old Apr 16, 2006 | 12:23 AM
Asobu's Avatar
ORIGINAL: WheelBrokerAng
To bad that wouldn't fit though.. lol
Old Apr 16, 2006 | 01:25 AM
mbo1985's Avatar
haha, you could make it fit. You don't need those pointless back seats, do you?
h22a1 is your best bet though if you want something that will for the most part bolt up (with the exception of a motor mount of two). As light said, you'll need the transmission and axles and of course, the ECU.
Have you thought about turboing that f? F's make sick turbo motors...
heh, i have the same exact car as you and I'm loving my turbo set up!
Old Apr 16, 2006 | 01:31 AM
Asobu's Avatar
Do you have MSN by chance?
Old Apr 16, 2006 | 01:48 AM
marbro's Avatar
ok seriously, what kind of suspension would you need to make that thing not bottom out on a crack in the road?! lol
Old Apr 16, 2006 | 02:48 AM
Asobu's Avatar
ORIGINAL: marbro
I think that would be the least of your worries if you are trying to get that into a honda.
