Engine swap nightmare!!!
Old Sep 25, 2005 | 06:01 PM
REDRUM JOKER
Default Engine swap nightmare!!!
I have a 95 accord lx,it had a OBD1 F22B2 non vtec in it and im swap'n in a OBD2 F22B1 vtec out of a 96 accord ex... im gona be runnin a OBD1 POA ECU,my problem is the wiring...i know i need to run some wires for the vtec solenoid and a couple other things but im not sure what all to run wires for or where they go on the ECU!!! My oyher problem is the distributors are different,is there anyway to wire the OBD2 dist. plug into the OBD1 harness,i want to keep the OBD2 dist. if possible...another thing is the crank shaft sensor??? PLEASE HELP!!!
Old Oct 23, 2005 | 10:40 PM
Evlampius's Avatar
Default RE: Engine swap nightmare!!!
you want help?? get your car in proffesional Mod guarage ! ..not a dealer ofcourse
Old Oct 24, 2005 | 10:25 AM
6thgen's Avatar
Why in the world would you want OBD2 on a car that already has OBD1? Are you you trying to make things harder on yourself? Most people are trying to get were you already are.
Old Oct 25, 2005 | 02:00 PM
Evlampius's Avatar
[sm=exactly.gif]
Old Oct 28, 2005 | 11:02 PM
REDRUM JOKER
Im goin to the OBD2 cuz my stock motor blew up & I already have a built OBD2 vtec that has less than 15k miles on it!!!
Old Oct 29, 2005 | 02:20 PM
6thgen's Avatar
You'll have an easier time converting the new engine to OBDI. There are harnesses already out there and based on the model/year of the car OBDI should be acceptable for emissions.
freddieP
Aug 10, 2010 04:11 PM
ohanahorse
Sep 28, 2009 08:49 AM
dr.ocular
Oct 26, 2008 08:30 PM
hatzipri
Nov 10, 2007 10:03 PM
flomasta
Feb 1, 2006 06:57 AM
