Engine Wont Start
Old Jan 18, 2007 | 05:01 PM
RoKnAzn's Avatar
Default Engine Wont Start
This is a 93 Honda Accord EX. This is my Brothers Card. The Water Pump went out a month ago and I decided Monday of this week to drop it off @ the Honda Dealership. When they Tried to crank it up today and drive it in the shop it wont crank. (I pulled the car to the shop with the Jeep). I was LIKE WTF. I didnt messed with it. He said that the wires are not getting any spark or anything. Anybody can help me out wat it is? dont want to get FAWKed..
Thanks
Anthony
Old Jan 18, 2007 | 05:08 PM
Default RE: Engine Wont Start
sounds like a distributer problem to me, thats the first thing i check when there isnt spark, well, after checking the spark plugs that is.
sir_nasty's Avatar
If the car isn't in your possession it's impossible to troubleshoot but I can attempt to give you a couple of ideas.... If it's not getting any spark it could be the coil, cap/rotor, Dead battery (if it's not even turning over), distributor....
Old Jan 18, 2007 | 05:42 PM
RoKnAzn's Avatar
ORIGINAL: sir_nasty
The car does have a dead battery.The Mech has it on a BatteryJumper. Im think it is thecap/rotor. It might have some film of grease on it..IDK.. I will talk tohim later today.. Anymore tips?
BTW: The Spark Plugs, Wires, Cap and Rotors has been replace 6 months ago.. Except the Coil and Distributor...
Old Jan 18, 2007 | 05:49 PM
sir_nasty's Avatar
did you use NGK plugs? if you used bosch plugs that's not good... they don't play well with honda's....
RoKnAzn's Avatar
Yes I did change them with NGK that this forum recommended me..Stock Parts...
Thanks
Anthony
Old Jan 18, 2007 | 05:59 PM
RoKnAzn's Avatar
Ground wire on the ECU came out and now it RUNS!!!!!
Anyways, He is going to start working on the timing belt and it is going tocost me total of $610 bucks.. It was $550...
Old Jan 18, 2007 | 06:05 PM
sir_nasty's Avatar
is he going to do the seals/water pump at the same time or is that a quote for the belt only? Have you considered doing this job yourself?
Old Jan 18, 2007 | 06:09 PM
RoKnAzn's Avatar
ORIGINAL: sir_nasty
He is a Honda Master/Head Mechanic. He is doing the Seals, Belts, Rollers, and water pump. I did and after I cant get the Crank Pulley Bolt off. I gave up.. Plus skewl started back up..
Anthony
Old Jan 19, 2007 | 01:42 PM
RoKnAzn's Avatar
Well, Phillip is going to pick up the Honda today... Parts that where replace where... WaterPump, Timing Belt, Balancing Belt, All the Oil Seals, Tension Rollers, One Heater Hose (Cause this whole problem the whole time), Turned Rotors, Oil Change with OEM Filter, Drained and Refilled Manual Tranny with Honda fluids, Valve Adjustment and fix the Ground on the ECU...All for $780 Bucks...
