Exhaust manifold weld
Hi folks :D
Now i recently purchased a new exhaust manifold on ebay which turned out to be slightly wrong, the one i currently have has a crack in it...ive enquired about a weld and ive been told it can be done and ive been qouted a good price. 80% cheaper than a new manifold ... any experience of this as i know its a cast iron weld and in the past had alot of bad rep |
It can be done if correct welding consumible is used, enough preheat, and slow cooldown (oven). Check youtube videos on welding cast iron.
Have you looked for a used part? This may be cheapest option. good luck |
(Post 292282)
Yes the weld will work & hold. I've had many crack manifold weld before.
