f22b1 block running h23 head/electronics
Old Sep 10, 2010 | 03:20 AM
80s-tuner's Avatar
Default f22b1 block running h23 head/electronics
Hi, sorry I don't have time for a proper intro. My name is TJ, and I am an experienced toyota engine swapper. I'm quite familiar with 3sgte, 3vzfe+t platforms going into MR2s and Celicas. I am new to hondas, and I'm considering taking on a customer project. That is, if I can get all my ducks in a row.
I have a well maintained 110,000 mile f22b1 out of a 94' accord ex. The donor was burnt by vandals destroying everything, except the engine bay. ECU was lost and harness was cut during removal. Customer has an H23 equipped 92' prelude with a bad motor.
Heres the plan, after port matching coolant passages, swap h23 dohc head on f22 block, install into prelude using prelude electronics, and transaxle. Am I missing anything?
Other cliffnotes:
my f22b1 has 5spd, axles shafts, subframe, alt, starter, ps pump, front hubs/brakes/mac. strut, intake, other various parts, everthing except harness and ecu.
Questions:
Is port matching the coolant passages necessary for this particular hybrid motor?
what timing belt? h23 spec?
motor mounts are same?
is the rest of my info correct?
Old Sep 10, 2010 | 07:28 AM
g22cd5's Avatar
Supper Moderator
Old Sep 10, 2010 | 11:31 AM
80s-tuner's Avatar
Thanks! that covers everything.
Old Sep 10, 2010 | 04:27 PM
g22cd5's Avatar
Supper Moderator
anytime...let us know how it turns out. Doesn’t sound like your customer is doing it for performance. But they will see a drop in power. It won't have the same power as the h23 had. But let us know how it turns out.
elmerochingon
Oct 25, 2012 10:21 PM
electronics84
Sep 9, 2009 02:07 PM
gosu08
Jan 24, 2008 07:04 PM
1993accordSE
Apr 15, 2005 11:30 AM
1993accordSE
Apr 1, 2005 09:41 PM
