Gearbox(transmission ) Oil Leakage
Hi last week after a driving in a hot weather (above 38 centigrade degree and above 150Km/h speed on a steep hill )I faced with this:
there was oil all over the ring and over the lots of things behind ,I thought it's the break fluid but it was not
upper side of transimission(Gearbox) is too much oil that I think oil is dropping from here in this image shows :👇👇👇👇👇
As you see there is alot of oil 👇👇👇👇👇
Is it possible that too much pressure as I mentioned at first ,resulted in a leakage from this part that I even don't know its name?Is it a safe
ty valve to relief the pressure?
Dose anyone know this part's name and its job?
This is an Accord 2013 6AT.
ty valve to relief the pressure?Dose anyone know this part's name and its job?
maryxie
Oct 6, 2009 08:50 PM
