H22A swap legality
Old Jan 11, 2007 | 12:13 AM
Shadow1992's Avatar
Default H22A swap legality
I have a '92 Accord Ex and I want to swap out the F22A6 for an H22A1....how legal would it be and what parts as far as emissions regulations are concerned must I keep?
Old Jan 11, 2007 | 02:18 AM
ejd715's Avatar
Default RE: H22A swap legality
There are many websites showing the "how to" for this swap. I never see anything mentioned about a legality issue. I would like to know this information as well, since im thinking about doing this in about 2 years.
Old Jan 11, 2007 | 07:20 PM
sir_nasty's Avatar
Depending on what state you live in most emessions test just check for how "clean" the motor burns and I would assume that as long as you are within those specifications you'd be ok..... You'd probably have to ask the emessions people unless someone here has done the tests themselves or lives in your particular state....
Old Jan 13, 2007 | 05:58 PM
miami honda's Avatar
and you can never swap and older motor to a newer year car is illegal in any state
[align=left] [/align]
Old Jan 13, 2007 | 10:14 PM
legionofone's Avatar
i call bs on that... i know i can run down to the junkyard and grab a 91 f22 and throw it into a 92 and not have ANY legality issues...
Old Jan 13, 2007 | 11:48 PM
poser_pilot6
Actually, he is on the right track. You can only swap in engines that are not in an older OBD bracket. Hence, you could NOT legally put a 91 engine into a 92, because 92-95 are OBD 1, and 91-prior are OBD 0. You can put OBD 1 or OBD 2 engines into an OBD 0 car, but not an OBD 0 or OBD 1 engine into an OBD 2 car.
Old Jan 14, 2007 | 12:21 AM
well i belive that the 91 accord is OBD1 right? anyway... that is true... u cant put a older engine into a car that has higher emmission regulations
Old Jan 14, 2007 | 12:32 AM
poser_pilot6
Nope, for Honda its 92-95 OBD 1, anything 91 or earlier is OBD 0. But really you could probably get away with the swap if you dont live in California lol. And I think you can still put an older engine in the car as long as its in the same OBD bracket (i.e. you could put a 92 engine into a 95 car) but Im not sure on that.
Old Jan 14, 2007 | 01:54 PM
marbro's Avatar
saying you cant put an older engine in a newer cause because of emissions standards is a moot point because of the fact if you go from obd 2 to obd1 or obd0 on a newer engine you lose emissions control and in most cases wont pass the emissions test
Old Jan 16, 2007 | 09:31 PM
hey the guy that called bs on what I said needs to read the law it is unlawfull to put a 92 engine into a 91
point blank regardles of how you feel
