H22a swap problem
Old May 12, 2009 | 06:42 PM
VTECSK8R88
Exclamation H22a swap problem
I just did a h22a swap in my 97 accord lx, i have it in and tryed to start it but it doesnt want to stay running, i dont why. Its getting fuel and spark and the timing im pretty sure is correct. It will start and will just shut right off, i dont know what is wrong, somebody help me please.
Old May 13, 2009 | 08:51 AM
Just to check out a simple silly coincidence, try to start it then don't release the key completely. Just enough so the starter quits running, but still hold the key against the spring. Flaky ignition switch is not very rare...
Old May 13, 2009 | 03:21 PM
jcocker03's Avatar
did you get the ecu/wiring harness from the same car you got the engine out of? also, can you get it to rev up at all?
Old May 15, 2009 | 01:30 AM
VTECSK8R88
I tryed the ignition thing and it didnt work. And yes i sent both wiring harnesses off the hasport performance and i have the p13 ecu that came with the h22a. I tryed pushing on the gas and it just dies, and every now and then a check engine light will come on, and its for a code 4, which is the camshaft position sensor . Then i turn the ignition switch off and its fine, until it pops up again.
hitek85
Feb 12, 2008 10:32 AM
boots
Mar 22, 2006 10:04 PM
zelseman
Jan 19, 2006 05:57 PM
9JordonAccord9
Jan 10, 2006 06:13 AM
LinX
Nov 8, 2005 03:43 AM
