h23 question
Old May 9, 2011 | 11:38 AM
deadaccord92's Avatar
Default h23 question
i just bought an h23 the guy said it needed the head rebuilt because he didn't have compression. i plan on staying with my sohc head from my f22 ,whats a good way to check to see if the rings on the h23 block are still good, the head was off when i got it and the top of the pistions and the cylinder walls look good the block looks like its in good shap drained the oil didnt look like anything was in it . thnak you
Old May 15, 2011 | 09:35 AM
g22cd5's Avatar
Supper Moderator
if he said the head need a rebuild then that's prob. why it would not hold compression. Do any of the valves look bent form what you can see???
I personally don't know a way to do a compression test on a engine with no head bolted on.
Old May 17, 2011 | 09:16 AM
no not buy looking at them there still in the head but some of the valves are still sticking out just a little 2 of them actually and the cams are out of the head , wich i plan on staying with my sohc i want the f22a6 head yet there hard to find i also came across an add on craigslist about someone selling a skunk 2 stage 2 cam in a f22a4 head for 150$ do you think that will work well with the h23 block.
Old May 19, 2011 | 06:23 AM
g22cd5's Avatar
Supper Moderator
doing the h23 block with f22a head is gonna be just as much as a pain as a h23 head on a f23 block You have to plug oil drain holes.
Custom head gasket ect.
Also your f22a6 head has a better vale train than the f22a4 head.
Now if you want to stick with you f22a6 full engine you can use some parts from a h23. The intake manifold from the h23 is a nice power adder. Also that head with the cam for 150?? ehhh Id pick it up for 100 not 150. If they didn’t change out the valve train with the cam I would not bother..cus you might end u having to change out the whole vale train.
But if you HAVE to do this f22a head on h23 block search on cb7tuner.com big talk over there about this swap
Jap.Doe
Jan 15, 2012 11:44 PM
poff1986
May 10, 2006 03:25 PM
longneck8769
Apr 10, 2006 05:13 AM
1993accordSE
Apr 15, 2005 11:30 AM
1993accordSE
Apr 1, 2005 09:41 PM
