i need your opinions
Old Sep 4, 2008 | 01:46 PM
  #21
patrickz's Avatar
Default RE: i need your opinions
i was looking on the garret website, and they have many different turbos. which one would be best suited for my application?
Old Sep 5, 2008 | 09:23 PM
  #22
patrickz's Avatar
wow, i fel like a dumbPOOP HEAD because i dont know anything, but how does this turbo look? http://wwwb oostplanet com/gt20.htm
also, if someone has the time, can they write out what other parts i willneed. this would be much appreciated.
thanks
Old Sep 5, 2008 | 09:27 PM
  #23
yeah that turbo will do it, if you want a cheaper route find a used 16g dsm turbo. as for other parts you will need a manifold obviously, down pipe, waste gate, blow off valve, boost control, injectors, engine management, charge piping..............
i am by no means a knowledgeable turbo guy, those are just what i thought of off the top of my head as almost all my friends are into the whole DSM thing
Old Sep 5, 2008 | 09:36 PM
  #24
patrickz's Avatar
is a boost control needed if i only plan on running 4 to 6 pounds?
whats the max stock internals can handle?
Old Sep 5, 2008 | 09:44 PM
  #25
ORIGINAL: patrickz
yes
i wouldnt run more than 10 on stock internals
of course some peoples motto is boost it till it blows then build it
Old Sep 5, 2008 | 09:52 PM
  #26
patrickz's Avatar
im sorry i keep asking you so many questions, but how much of a gain will 6 pounds give?
Old Sep 5, 2008 | 09:54 PM
  #27
the standard is about 10hp per 1psi give or take
Old Sep 5, 2008 | 09:57 PM
  #28
patrickz's Avatar
60 hp sounds pretty good to me. btw, how much power can an automatic transmission take?
Old Sep 5, 2008 | 10:03 PM
  #29
if you ran a tranny cooler to it, it should be fine, because heat kills transmissions, and the more power would cause more heat
heres a general turbo guide
http://www gen5alive com/forumshowthread.php?t=176
and heres a guys build on a f22b1 with a slushbox tranny running 7psi
http://www.com/forums/showthread.php?t=5963
Old Sep 5, 2008 | 10:10 PM
  #30
patrickz's Avatar
ill take a look
