I want more power from a 96 F22.
Old Mar 23, 2009 | 08:31 PM
gabe.weisberg
Default I want more power from a 96 F22.
hey there so i got a 1996 honda accord lx with a 2.2L I4 non-V-TECH motor, and i want to do something to beef it up some more. i am not exactly the best with cars but i can still figure stuff out pretty well. so far i have installed(all by myself, which i am very proud of),
AEM V2 cold air intake
pacesetter 4-1 stainless steel header
full N1 style catback system with 2.5inch pipe straight to a 4inch pipe
that is all that ive done and im looking for some good ideas for my next project- i have access to a hydralic lift and to almost any tool required for a car. so any ideas please tell me!
also if anybody knows of a good way to clean up and engine block lemme know. im also on AIM-bluesroll is my sn
Old Mar 24, 2009 | 07:53 AM
Welcome new member!
This area is mostly for newbie introductions. I'm gonna move this to a technical forum (engines/internals) where more people should respond with real answers.
edit...
Well, maybe if I change the title it can attract some attention.
Check out the ongoing conversation about more power for a 94. Yours is pretty similar.
Old Mar 27, 2009 | 08:10 PM
HundoGuy
Dude i hate to tell yah but the 2.5in exhaust to a 4in isnt doing you any good unless your turboed its just taking all of the back pressure
Old Mar 28, 2009 | 10:14 AM
falkore24's Avatar
I'm almost positive that he means 2.5" pipe with a 4" tip on the muffler. IMO, 2.5" is a bit large for a 4 banger NA .... I think 2.25" would be better. I've seen an EVO2 setup on an SI with a K20 and that worked well with 60mm piping. 2.5" isn't terrible, but not ideal either. I don't even think 4" piping would fit the OEM routing and bends, but you never know.
FYI - I plan to use 2.5" piping on my tC for a 2.4L engine turbocharged.
EDIT: For the poster above me ..... backpressure requirements are a myth however proper flow regime is not. The reason for losses on a NA due to an inappropriately sized exhaust system is due to the large volume of gas that has to be moved and too low a flow velocity to maintain a fully uniform and turbulent flow. To add to the problem, piping is typically a constant size as you move toward the rear of the car, yet the exhaust is cooling rapidly which caues it to contract and lessen the flow even more as the muffler is approached. Backpressure is a similar explanation that is widely accepted, but is fundamentally wrong. No intent to step on any toes, just some info.
Tyrene
Oct 7, 2012 04:42 PM
AbaZ
18
Jul 16, 2008 10:23 PM
pace
Apr 17, 2008 04:40 PM
SpanishN00b
Jul 29, 2007 07:11 PM
dave118811
Mar 26, 2006 11:09 PM
