idling problems
Old Nov 26, 2007 | 11:13 AM
94Honda's Avatar
Default idling problems
when my car is cold and i start it up itll stay around the 2000rpm range and when it drops down to 1500 itll bounce back up to 2000 then back down and back and forth. anyone know y or how to solve?
Old Nov 26, 2007 | 12:12 PM
nafango2's Avatar
Default RE: idling problems
im definetly not an expert on this (or anything close)... but i think it might be related to your fast idle thermo valve ... or FITV. But before you do anything about it wait for a more knowledgeable member to chime in....
Old Nov 26, 2007 | 01:54 PM
94Honda's Avatar
where is this valve located and what does it look like?
Old Nov 26, 2007 | 02:22 PM
sir_nasty's Avatar
You could always go to our DIY section and read the surging idle post. Here's a link
https://www.hondaaccordforum.com/SUR...m_46125/tm.htm
Old Nov 29, 2007 | 11:15 AM
94Honda's Avatar
well i checked out the post and it helped out some but my motor dosent look like that idk where the fitv is or any of the idling components i got a clue but dont know what is what. Also i reset the ecu and it helped some, the car would get half warm then it would start doing it, then i'd put it in gear "its an AT btw" and leave it in gear for 20 sec. then put it in park again andit wouldnt do it, but if i touched the gas it would do it until completly warm.
Old Nov 29, 2007 | 11:37 AM
Underneath your throttle body, #14 is the FITV.
On the back of the intake manifold, #19 is the IACV.
Make sure you first eliminate any vacuum leaks & bleed the air out of your cooling system.
Also be aware that many people have had troubles using Bosch spark plugs in Hondas (I noticed them in your signature).
Old Nov 29, 2007 | 11:38 AM
00AccordLX5spd's Avatar
Registered User
Does your signature say you have Bosch spark plugs? If that is the case you may have fried your coil. Better take those Bosch plugs out immediately and replace with NGK.
Old Nov 29, 2007 | 11:50 AM
94Honda's Avatar
thanx for the help. whats wrong w/bosch? what NGK's should i run, iridium?
94Honda's Avatar
ahn how do i bleed the cooling sys of air?
Old Nov 29, 2007 | 11:54 AM
Registered User
For some reason Bosch plugs fry Honda coils. Any brand NGK will do. The double platinums cost a lot, but they are supposed to last 100k miles. I don't really know anything about iridiums. Double plats came stock in 2000 & newer models so I just bought 4 of them for my LX, but I haven't gotten around to changing them out yet.
Check the prices atAdvance Auto Parts. I got them cheaperat Advancethan on sparkplugs.com!
