K series info and Specs
Old Nov 5, 2010 | 05:32 PM
g22cd5's Avatar
Supper Moderator
Arrow K series info and Specs
K20A2
Found in:2002-2004 RSX Type-S (USDM)
2002-2004 Honda Integra Type R (Australia)
2002-2005 Honda Civic Type R (EP3, European)
Displacement: 1,998 cc (121.9 cu in)
Compression: 11.0:1
Power: 200 hp @ 7800 rpm
Torque: 141 ft·lbf (196N·m) @ 5600 rpm
Rev limit:8200 rpm (USDM RSX-S, U.K Civic-R )
i-VTEC engagement: 5800 rpm
K20A3
Found In
2002-2005 Honda Civic Si (EP3)
2002-2005 Honda Civic SiR (EP3)(Canadian version of US Civic Si)
2002-2006 Acura RSX
Compression: 9.5:1
Power: 160 hp(120 kW) @ 6500 rpm(SAE net J1349 Rev 8/04)
Torque: 140 lb·ft (190 N·m)* (191 N·m) @ 5000 rpm(SAE net J1349 Rev 8/04)
Redline: 6700 rpm
i-VTEC Engagement Window: 2200 rpm
K20A4
Found in:
2003-2005 Honda Accord (UC1)
2006-2008 Honda Accord (UC3)
2001-2007 Honda CR-V (RD5)
2000-2003 Honda Stream (RN1)
2004-2007 Honda Stream (RN3)
K20A6
Found in:
2003-2005 Honda Accord (European)
Compression 9.8:1
Bore / Stroke 86 mm x 86 mm
190 nm Torque @ 4500rpm
155 hp @ 6000rpm
K20Z1
Found in:
2005-06 Acura RSX Type-S
2005-06 Honda Integra Type-S (Australia)
Compression: 11:0:1
Power: 210 hp (154 kW) @ 7800 rpm
Torque: 143 ft·lb (194 Nm) @ 7000 rpm
Redline: 8300 rpm
i-VTEC Engagement Window:5800 rpm
K20Z2
Found in:
2006- Acura CSX (Canada)
Compression: 9.6:1
Power: 155 hp (114 kW) @ 6000 rpm (SAE net J1349 Rev 8/04)
Torque: 139 ft·lbf (188 N·m) @ 4500 rpm
Redline: 6800 rpm
2006- Honda Civic (JDM)
Compression: 9.6:1
Redline: 6800 rpm
2006- Honda Accord (Europe)
Displacement: 1998 cc
Compression: 9.6:1
K20Z3
This inline-4 cylinder internal combustion engine is found in the US market Honda Civic Si (2006+) & Canadian market Acura CSX Type-S. It has an aluminum block with an aluminum head, and a bore and stroke of 86 mm x 86 mm, resulting in a 1,998 cc (121.9 cu in) displacement.Found in:
2006-2011 Honda Civic Si (FG2 - Coupe & FA5 - Sedan), 2007-2010 Acura CSX Type-S
Displacement : 1,998 cc (121.9 cu in)
Compression : 11:1
Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 140 ft·lbf (189 N·m) @ 6200 rpm (sae NET Rev 8/04)
Redline: 8000 rpm
Fuel Cutoff: 8300 rpm
K20Z4
Found in:
2007-2010 Civic Type R (EDM) (FN2)
Compression : 11:1
Power: 198 bhp (148 kW) @ 7500 rpm
Torque: 142 ft·lbf (193 N·m) @ 5600 rpm
Redline: 8000 rpm
i-VTEC Engagement Window:5400 rpm
K23A1
Turbocharged
Found in:
2007-2011 Acura RDX[1]
Displacement: 2,300 cc (140.4 cu in)
Compression: 8.8:1
Power: 240 hp (179 kW) @ 6000 rpm (SAE net)
Torque: 260 lb·ft (353 N·m) @ 4500 rpm (SAE net)
Redline: 6800 rpm
Bore: 86 mm
Stroke: 99 mm
K24A1
Found in:
2002-2006 Honda CR-V
Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (120 kW) @ 6000 rpm
Torque: 162 ft·lbf (220 N·m) @ 5200 rpm
Redline: 6500 rpm
K24A2
Found in:
2004-2008 Acura TSX, JDM CL9 Accord Type-S, RB1 Odyssey Absolute
Power: 200 PS (150 kW; 200 hp) @ 6800 rpm
Torque: 232 N·m (171 lb·ft) @ 4500 rpm (166 lbft @ 4500 rpm U.S.)
Bore: 87 mm
Stroke: 99 mm
Compression: 10.5:1
Redline:
Automatic 7100 rpm
Sequential Sportshift 7300 rpm (7100 rpm U.S.)
Manual 7600 rpm (7100 rpm U.S.)
Note: The 2006-2008 K24A2 in the U.S. market Acura TSX has the following improvements[2]
Power: 205 hp @ 7000 rpm
Torque: 164 lbft @ 4500 rpm
Increased intake flow:
Intake valve + 1 mm oversize
Intake cam High lift lobe with 0.9 mm more lift and 12 degrees more duration
Throttle body increased from 60-64mm
Radius on some intake pipes increased from 70-80mm
Increased exhaust flow
Exhaust Head pipe increased frm 60-65mm
Higher flow catalytic converter
Main (single) exhaust pipe increased from 54-57mm
Rear (twin) pipes increased in diameter from 42.5 to 45mm
Block improvements:
Additional air passages in crankcase for reduced pumping losses
Other
Stronger conrods
New crankshaft with more counterbalance weight
Revised pistons with more valve-piston clearance
K24A3
Found in:
2003-2007 Honda Accord (Europe(EDM)) and Japan(JDM)) and 2003-2007 Honda Accord Euro CL9 (Australia)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 10.5:1
Power: 189 hp (140 kW) @ 6800 rpm
Torque: 164.5 ft·lbf (223;N·m) @ 4500rpm
VTEC Engagement: 6000rpm
Redline: 7400rpm
K24A4
Found in:
2003-2005 Honda Accord(USDM), 2003-2006 Honda Element
Compression: 9.7:1
Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
0/100: 7,9 Sec
Torque: 161 ft·lbf (218 N·m) @ 4500 rpm (@4000 rpmin 2007/2008)
Redline: 6800 rpm
K24A8
Found in:
2006-2007 Honda Accord
Compression: 9.7:1
Power: 166 hp (124 kW) @ 5800 rpm
Torque: 160 lb·ft (217 N·m) @ 4000 rpm
Redline: 6500 rpm
2007-2008 Honda Element
Compression: 9.7:1
Power: 166 hp @ 5800 rpm
Torque: 161 lb·ft (218 N·m) @ 4000 rpm
Redline: 6800 rpm
K24Z1
Found in:
2007- Honda CR-V (RE3, RE4)
Compression: 9.7:1
Torque: 161 ft·lbf @ 4200 rpm
Redline: 6500 rpm
K24Z2
Found in:
2008 Honda Accord LX/LX-P trim models
Compression: 10.5:1
Power: 177 @ 6500 rpm
Torque: 161 ft·lbf @ 4300 rpm
Redline: 6800 rpm
K24Z4
Found in:
2008+ Honda CR-V (RE7)
Compression: 9.7:100
Redline: 6500 rpm
K24Z5
Found in:
2009+ Honda Spirior
Compression: 10.5:1
Power: 184 @ 6500 rpm (133 kW @ 6500 rpm)
Torque: 164 ft·lbf @ 4300 rpm (225Nm @ 4300 rpm)
Redline: 6800 rpm
K24Z6
Found in:
2010 Honda CR-V (all trim models)
Compression: 10.5:1
Power: 180 HP @ 6800 RPM
Torque: 161 lbs·ft @ 4400 RPM
Readline: 7100 RPM
If you have any info you can contribute I will add it.
NO USELESS POST THEY WILL BE DELETED
g22cd5
Jun 26, 2011 11:50 AM
g22cd5
Jul 30, 2009 07:15 PM
theirlaw
May 8, 2009 01:14 PM
BuntinBoy9
Nov 11, 2007 06:56 PM
cbondhonda
Jul 21, 2007 07:10 PM
