low end tourqe
Old Feb 23, 2009 | 02:39 PM
finch13's Avatar
Yeah that diesel was supposed to be on some 09 Accord's, but it never happened.
Old Feb 23, 2009 | 04:14 PM
t00fatt's Avatar
Originally Posted by finch13
Torque? Honda? I don't think those two words can be put in the same sentence together.
What?? My K24 is torquey as *****!!.... For an i4 that is lol
Old Feb 23, 2009 | 07:26 PM
baconsum1's Avatar
if i have a test pipe will get pulled over out here.. i think i roll with the header and then sway bars and then i might start messing with the throttle body
Old Feb 23, 2009 | 11:10 PM
clutch811's Avatar
its technically illegal in all states i believe but not all check. watch basically for e-check and such. i dont recommend it instead they do make high flow cats which apparently give similar results. not much gain to be had anyway. sounds like a plan though. good luck!
Old Feb 24, 2009 | 11:52 AM
jcocker03's Avatar
yeah im pretty sure the test pipe is illegal in all states, but if you live somewhere like WI where they don't emission test you only get pulled over for exhaust if its "louder than normal". As long as your not stupid enough to tell the cop you have a test pipe instead of a cat your good to go over here.
and test pipes are cheaper than high flow cats
Old Feb 24, 2009 | 01:04 PM
baconsum1's Avatar
na im from CT and we got emissions and sound patrol so im gonna stay waway from a test pipe. thanks for the input. i'll post new pics when im kited up so u guys can see what your building
chrw
Jan 26, 2011 06:12 PM
steviebix
Nov 21, 2007 10:52 AM
liam71234
Nov 5, 2007 02:57 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
6genex
Oct 9, 2007 04:15 PM
