Lower mpg
i own a 94 f22b2 engine and i has been runnin great except for one lil problem now. im not getting enough mpg as i used to. im talkin like 4-5 mpg at least. i have noticed that my engine idle had been gettin lower(yes its a manual) also there has been more "black sut" on the exhaust pipe. also i dont know if this could help but i just put 18" enkei rims on there too. i went from 14 X 5.5 to 18 X 7.5 and my car raised about an inch too. could this factor in too????
RE: Lower mpg
I don't think so, but the "black sut" on the tip of the muffler means it's not burning the amount of fuel it should..... try changing the sparks and checking the spark plugs.... that might help....
RE: Lower mpg
The larger wheels will cause your odometer to falsely read that you have traveled fewer miles. This will lead to a false lowermpg calculation. It will also throw your speedometer out of whack. Right now your speedo will show you are going slower than you really are.
RE: Lower mpg
00: you stole my interjection!!! Theif!!!! [sm=joke.gif]
RE: Lower mpg
ok awsome i knew that the odometer would be off but it didnt connect to me that it would read false mpg too [:'(]duhhh but thats cool also i am going to try the spark plugs with prolly ngk iridiums cuz i heard those are good. (are they???) also do you know where i could take my car to get the speedo corrected and how much it could cost???
RE: Lower mpg
A friend of mine said that he corrected his with an Apexi Rev & Speed meter, but Apexi doesn't list this function so I'm not sure. He showed me a screen on it that allows a % adjustment of tire circumferance compared to stock, but I don't think that it has the connections to adjust the speedo readout. I'll get in touch with him and get back to you.
RE: Lower mpg
appreciate it
RE: Lower mpg
Just out of curiousity did you raise the car just so you could fit the tires under?
RE: Lower mpg
I just looked up the wiring diagram and it does have the connections to adjust the speed signal to the ECU, so I think that this would work for you. You should email Apexi to verify though.
RE: Lower mpg
ok cool i will defintnly email apexi tonight and no i definently did not raise my car to put them on there..... i hate donks. but just because of the nature of putting rims that where 4 inches bigger it raised it some
