MID GRADE GAS
Old Sep 27, 2008 | 02:24 PM
Mikkos's Avatar
Default MID GRADE GAS
Hi guys,
I have a 2001 Accord Ex 4cyl, and currently have 238,000 miles on it. Car is running fine as usual. I wanted to know would it be a safe choice to start using mid-grade gas? I'm just curious to know if this would help or hurt. I currently use regualr unleaded of course..
Old Sep 27, 2008 | 07:33 PM
RTexasF's Avatar
Super Member
Default RE: MID GRADE GAS
Why spend more money on fuel when regular has worked just fine for 238,000 miles????????? [sm=interesting.gif][sm=interesting.gif] I don't get it!
Old Sep 27, 2008 | 07:43 PM
i'm with RTexasF there is no reason to switch, the car was intended to run on 87 octane
Old Sep 28, 2008 | 12:07 PM
03Sleeper's Avatar
No reason to switch considering the car is made to run on 87 octane. Read the manual man!
Old Sep 28, 2008 | 02:52 PM
klrspz's Avatar
... and read the octane specifications.
Old Sep 28, 2008 | 02:55 PM
finch13's Avatar
Some people just confuse me...
Old Sep 28, 2008 | 05:19 PM
falkore24's Avatar
Pretty soon I'm going to high test ..... most likely in the spring.
Old Sep 29, 2008 | 09:28 PM
smaglik's Avatar
waste of $.
Old Sep 29, 2008 | 09:35 PM
blinkz0rz's Avatar
If you want to spend $1 - $2 more at the pump, then do so. Otherwise, getting 89 doesn't really do anything for your car. Same with 92 octane, as that is intended for high compression engines around 11:1 and your Accord has 9:1.
Old Sep 30, 2008 | 02:41 PM
falkore24's Avatar
ORIGINAL: smaglik
waste of $.
When my engine is putting out twice the power that it came with and DOESN'T knock, I'll accept the extra $1-2 at the pump.
