need help
Old Apr 23, 2012 | 11:28 AM
FTPaccord90's Avatar
Default need help
i need to kno which timimg belt too use tu put an f20a head on my f22 block
Old Apr 23, 2012 | 01:27 PM
f20a? Are you in America?
Old Apr 23, 2012 | 03:00 PM
yea im in america its supposed tu be a non vtec f20 head it bolts on to the block i had to use an h23 head gasket but no luck wit the h23 timing belt
Old Apr 23, 2012 | 06:34 PM
single over head cam? I'd try a f22 timing belt and maybe use a f22 cam gear.
Old Apr 24, 2012 | 01:18 PM
no its its twin cam somebody told me it f20a kuz its non vtec but another guy said its f20b idk man i jus need tu kno wht timing belt to use some body told me h23 but tat didnt work nd no someone else saying i shud use a gsr timing belt idk man im confused
Old Apr 24, 2012 | 01:32 PM
Old Apr 24, 2012 | 05:31 PM
Can you post a picture of the valve cover? That might help us figure out what the head actually is, which can then help figure out what timing belt is going to be needed.
F20Bs are DOHC VTEC.
F22B(JDM) are DOHC non-VTEC and the valve cover looks like this:
Old Apr 24, 2012 | 07:04 PM
it looks jus like that man i guess its a f22b head
Old Apr 24, 2012 | 07:28 PM
I could only find one person that had done that and they said thye used this:
gsr or h23 timing belt
h23 crank timing pulley with backing plate
h23 external coil or h22 distributor internal coil
h23 intake manifol will work the best with this swap, other than that your original f22a head gasket will match perfect and the f22b head will accept h23 cams,springs and retainers.
Old Apr 25, 2012 | 09:45 AM
thanks man im goin tu gather up some parts
99accordf23a5
May 6, 2014 12:51 AM
brandyn
Nov 26, 2013 05:31 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
ryan ortego
May 19, 2005 06:06 PM
