Need help with 91 accord ex
Old 10-14-2014, 02:33 PM
woody31's Avatar
Almost A Senior Member
If it stumbles and dies,,no check engine light,,how long has it been since the fuel filter was changed,, also check fuel pressure,, but remember ,,, just because you have pressure does not mean you have volume,,good luck.
Old 10-14-2014, 02:55 PM
mickey37388's Avatar
I dont know on either of those. I have a fuel fliter I could put in it now but could the filter cause all much as its doing? Also its been doing this for lil over a week now.
Old 10-14-2014, 05:53 PM
Ok it has a new fuel filter but still no start. Gonna replace the pump tomorrow
Old 10-15-2014, 07:46 AM
Are you not hearing the fuel pump when turning keyswitch to On? Pump should come on and run for 2-3 secs, then go off. If you do hear the fuel pump, then replacing fuel pump is unlikely to help.
Problem may be Main Fuel Relay and not fuel pump. Replacing fuel pump is a pretty big job to do just to see if it will help.
Old 10-15-2014, 01:04 PM
Had to be the relay. New fuel pump is in and not working. Would the fuel sender unit be the problem?
Old 10-15-2014, 02:05 PM
Only if fuel level is too low to provide fuel to fuel pump.
Old 10-15-2014, 02:11 PM
Ok this is driving me nuts. Just got the new relay in and there is about a quarter tank of gas in the tank with the new fuel pump in and its still not kicking the fuel pump on.
  #18
Old 10-15-2014, 02:56 PM
Power is likely missing, perhaps a fuse blown or faulty ignition switch.
Check ECU fuse 28 (10A underhood fuse box), fuse 2 (15A under dash fuse box), and fuse 9 (7.5A underdash fuse box).
If fuses are good, check blk/yel wire at under dash fuse box (pull fuse 2 and check both contacts, one should be hot w/ keyswitch On.
If no power to fuse 9, ignition keyswitch assy is faulty and must be replaced (a common fault).
Old 10-15-2014, 04:14 PM
Fuse nine does not have any power.
  #20
Old 10-15-2014, 04:53 PM
<<<@!1!@>>>
If fuse 9 has no power (keyswitch On?) to either socket, then ignition switch is not passing power and new ignition switch assy should be installed.
Check youtube videos. Here is one of the better videos. Different year but very similar to yours.
Quick Reply: Need help with 91 accord ex
