Need Info on converting Auto to Manual trans.
Old Jul 24, 2008 | 09:28 PM
ford's Avatar
Default Need Info on converting Auto to Manual trans.
Sup everyone? anyways i was wondering how hard is it to convert a automatic to manual transmission? What items do i need to if i wanted to convert my auto to manual trans? I am asking this because i am thinking that if my auto trans breaks and needs replacement, im gonna consider converting it to manual cuz that was what i really wanted to have in the first place...
Old Jul 24, 2008 | 11:40 PM
Default RE: Need Info on converting Auto to Manual trans.
Lots of little parts & tremendous amount of labor. If you pay to have a shop do it, its probably not worth it.
Doing it yourself??
Possible start for your shopping list?
Several console parts around gearshift lever.
Gearshift lever & structural stuff around there.
Shift cables, with their brackets & etc.
Rear engine mount (below firewall) is different.
Tranny (duh)
Flywheel (& longer bolts for crankshaft)
Clutch & pressure plate & pilot bearing.
Brake/clutch pedal assembly.
Wiring for clutch-starter interlock, solenoids, etc.
Clutch master cylinder & hydraulic lines.
Possibly the starter is different?
ECU for manual, or learn what jumpers/connections to change.
Old Jul 24, 2008 | 11:58 PM
Now that's a shopping list that will keep you busy if your thinking of doing it ...not for me but for you maybe [sm=pimp.gif]
Old Jul 25, 2008 | 08:09 AM
BlkCurrantKord's Avatar
Shifter cables
Slave cylinder
Clutch resevoir
Clutch lines
Clutch/Flywheel
Flywheel bolts
5spd Starter + bolts
Manual trans + bolts
5spd ecu (obd1)
Clutch pedal
Its been done before, its fairly straight forward and cheap now a days. There's also several write ups that make it 10x easier.
Old Jul 25, 2008 | 09:11 AM
00AccordLX5spd's Avatar
Registered User
When the forum is finally back up and running correctly, there is a DIY on page 3 of the DIY section. Right now the link doesn't work though [:@]
Old Jul 25, 2008 | 12:07 PM
ford's Avatar
ok thanks guys..yeah ill still gonna do alot of researching on this topic b4 i think bout taking this on..=D..thanks for all the info guys...
Old Jul 25, 2008 | 12:33 PM
falkore24's Avatar
ORIGINAL: 00AccordLX5spd
When the forum is finally back up and running correctly......
Try back sometime in November.
Crazyguy
Jul 5, 2010 08:31 AM
mmazb3
Nov 26, 2007 03:16 PM
kaotikcariz
Aug 6, 2007 08:06 PM
honda212
Dec 11, 2006 01:36 AM
1a9c9c9ord
Nov 28, 2006 10:28 PM
