New Question Up For Your Entertainment...
Old Jan 3, 2005 | 05:37 AM
Default New Question Up For Your Entertainment...
Here is a new question for you to put on your thinking caps for...
Your trans-axel will not downshift with your accelerator pedal pressed to the floor------What is your Answer...
WheelbrokerAng[sm=pimp.gif]
Old Jan 4, 2005 | 10:49 AM
RTexasF's Avatar
Super Member
Default RE: New Question Up For Your Entertainment...
Downshift detent cable has come loose under the hood.
Old Jan 6, 2005 | 11:19 PM
maxst2
Usually you have to downshift it. Being a stick shift...its kinda required.
I've never heard an auto tranny called a trans-axle, just manual.
But if it is auto..i would say its...either bad clutch packs or torque converter.
:P
Old Jan 10, 2005 | 01:26 PM
[sm=imsorry.gif]I'm sorry....wrong answer....
One more try my Friend....
Old Jan 10, 2005 | 01:46 PM
Yes my Forum Friend ...there is what is refered to at the Honda Dealer a
Automatic Transaxel.
Reference as follows...all vehicles come equipped with either a five speed manual or a four speed automatic transaxel.
Due to the complexity of the Automatic TransAxel which takes specialized equipment necessary to perform most service operations , routine maintenance, adjustments and removel and reinstallation of your TransAxel should always left up to a dealer service department or to an automotive or best ; transmission repair shop...And By The Way...I dont work for either one of those type companies[sm=smiley16.gif]
Hope that this helps out your answer..Now get me a good answer,Thanks!
WheelBrokerAng[sm=smiley14.gif]
Old Jan 15, 2005 | 06:04 PM
bonylad
Transmission fluid could be low.
A/T control unit faulty?
Any codes? Flashing D light?
Melissa
Aug 25, 2009 12:44 AM
lvp0412
May 13, 2009 07:30 AM
importedminds
Aug 6, 2008 08:43 PM
sir_nasty
Jan 16, 2007 11:58 PM
Honda_Dude
Jan 13, 2007 08:11 PM
