No crank
Old Nov 22, 2015 | 05:34 PM
Moochdog's Avatar
Default No crank
Hey guys I have a problem with my 2002 accord special edition sedan. it started one day just fine I moved it cross my yard and was playing music from my radio so I got ready to start it to keep the battery up it wouldn't start just click so I tried to jump it off with 3 different cars still no luck. So I swapped batteries still no start next I tested to see if I was getting power to the solenoid I had power to it so I figured it was the starter so I bought a new one and still the same results
So I just unhooked the starter signal wire I used jumpe wire bypass it would do is click still won't engage. I check the computer for codes no codes. I'm at the blank page here i don't know what could be the problem I was thinking the ignition switch could be bad because of the new starter but could the thief system but keeping it from working. If anyone can help I'll be so glad I just bought a transmission that didn't work from JDM Tiger Japanese for $500 so I'm kinda frustrated with that cause I really want my car running.
Old Nov 26, 2015 | 11:03 AM
It sounds like a weak battery or battery connection. Pull both cables from the battery and clean all of the ends of the cables and be sure when they go back on they are tight. Have the battery tested and be sure it is good.
eazyazamp
Apr 5, 2007 01:52 PM
dnask8ter
Mar 14, 2007 02:20 PM
mgreisamer
Feb 27, 2007 08:24 PM
RoKnAzn
Jan 5, 2007 02:27 AM
brayner
Dec 19, 2006 08:18 PM
