No vtec......
Old Jan 17, 2009 | 11:31 PM
skatingclaybird's Avatar
Default No vtec......
Now its my turn to ask yall......ok my accord is boosted right! well igot my car back from the shop and half the time my vtec wont "Kick In" ya know. So ive been through the normal pocedures.
1. Normal Oil Level
2. Just replaced Vtec solenoid,Spark plugs with NGK Iridium ik22,rotor and ignition cap,and wires
3.oil pressure switch is hooked up.
4. Good Oil.
what else could cause the prob. sometimes it will kick in and then quit and work again. So what do you thnk could cause the prob.
Thanks Guys
Old Jan 17, 2009 | 11:34 PM
Tippman7641's Avatar
Default RE: No vtec......
[sm=massbounce.gif][sm=laughat.gif] wah wah wahhhhhh, im srry after reading the post title i had to say that, the little screen right below the solineoid is clogged?
Old Jan 18, 2009 | 12:23 AM
cjdm98's Avatar
Im assuming your running at least a decent ECM,I would check speed sensor,as it sends information to the ECU,Also even though you checked the oil,it may be due for a change.You should at least be throwing a code or 2.
Old Jan 18, 2009 | 12:44 AM
its a brand new solenoid i dont think it is clogged but maybe and also i just changed the oil .....yah it throws the p1259 vtec mal/f code....and what would of caused the speed sensor to be bad.....it did sit for a year in a shop and at idle ive been getting that honda sickness when it idles up and down without having to touch the gas....?
Old Jan 18, 2009 | 02:13 AM
BlkCurrantKord's Avatar
Change the oil/filter, check the screen, reset the light. See what happens.
Old Jan 18, 2009 | 02:53 AM
all of those has been done
Old Jan 18, 2009 | 06:43 AM
Still have a code?
Old Jan 18, 2009 | 02:31 PM
p1259
Old Jan 18, 2009 | 04:44 PM
cjdm98's Avatar
Take it back to "the shop"
Old Jan 18, 2009 | 05:54 PM
HAHAHAHAHAHA .................NO!!!!!! j/k
