oil been leaking, now green?
Old Dec 24, 2007 | 05:53 PM
noboundaries6289's Avatar
Default oil been leaking, now green?
hey all, my oil has been leaking in the past. So wat. Now, i backed out of the driveway today and there is a green mixture in the mix. I know this is radiator fluid (i think) but it's not on the dipstick (oil). So I don't think i have a blown head gasket. My fluids are adaquate and I topped them off today. Any suggestions on where this leak could be coming from?
PS: new timing belt, balance shaft belt, and water pump installed less than 10k ago along with various seals and gaskets.
Old Dec 24, 2007 | 09:50 PM
19Accord97
Default RE: oil been leaking, now green?
Just because both are there does not 100% mean they are mixing within the engine. Most likely you have a small hole in the radiator or in a line and now both are leaking (oil, coolant).
Old Dec 27, 2007 | 03:56 PM
sir_nasty's Avatar
either that or it could be the bearing on your water pump going out. The new pump may have issues, check the weep hole at the back/bottom of the block and see if it's there
Hicksvilleshick
Aug 13, 2015 11:40 AM
blaz72282
Oct 29, 2013 02:17 PM
karter25
Jan 18, 2012 08:06 AM
HondaAficionado
Oct 18, 2011 07:50 PM
nygamble
Jun 11, 2006 07:13 PM
