piston
Can i put the H22 piston in my 1990 honda accord
RE: piston
Sure..open the door, place it on the seat. Ta-da, its in your 1990 accord.
RE: piston
lmao nyce one blkcurrantkord
i pretty sure u can i hae a friend that is putting it on a 93 accord |
RE: piston
you have to bore out the cylinders i believe 2mm and you will have to replace the rods with customs to match the pin thats used with a h22 piston but i would have to double check on the rods
RE: piston
I should be able tojustget theh22 piston n rods n bore it over n put them n right
RE: piston
engine management and a different fuel map would help a bit a well and new rings of course
RE: piston
Boring it out 2mm would not be recommended. You'll also need some work to the combustion chamber on the head. Sleeve the motor or just get an H22.
RE: piston
So what is the map fuel for n i am going to boost it thats why i want yo keep that one.
RE: piston
The fuel map controls how long the injectors stay open for (in milliseconds). Hence, they usually need to be shortened when you add a higher flow fuel pump and bigger injectors, which is usually what you do if you turbo.
RE: piston
Ok so if i am not going to boost it now i dont need to do that
