piston
Old Feb 19, 2008 | 09:31 AM
22psi's Avatar
Default piston
Can i put the H22 piston in my 1990 honda accord
Old Feb 19, 2008 | 12:02 PM
BlkCurrantKord's Avatar
Default RE: piston
Sure..open the door, place it on the seat. Ta-da, its in your 1990 accord.
Old Feb 20, 2008 | 11:46 PM
DA KID RYU's Avatar
Default RE: piston
lmao nyce one blkcurrantkord
i pretty sure u can i hae a friend that is putting it on a 93 accord
Old Feb 21, 2008 | 10:05 AM
marbro's Avatar
Default RE: piston
you have to bore out the cylinders i believe 2mm and you will have to replace the rods with customs to match the pin thats used with a h22 piston but i would have to double check on the rods
Old Feb 21, 2008 | 11:36 AM
22psi's Avatar
Default RE: piston
I should be able tojustget theh22 piston n rods n bore it over n put them n right
Old Feb 23, 2008 | 11:09 AM
marbro's Avatar
Default RE: piston
engine management and a different fuel map would help a bit a well and new rings of course
Old Feb 23, 2008 | 11:29 AM
Default RE: piston
Boring it out 2mm would not be recommended. You'll also need some work to the combustion chamber on the head. Sleeve the motor or just get an H22.
Old Mar 4, 2008 | 09:41 PM
22psi's Avatar
Default RE: piston
So what is the map fuel for n i am going to boost it thats why i want yo keep that one.
Old Mar 4, 2008 | 09:47 PM
finch13's Avatar
Default RE: piston
The fuel map controls how long the injectors stay open for (in milliseconds). Hence, they usually need to be shortened when you add a higher flow fuel pump and bigger injectors, which is usually what you do if you turbo.
Old Mar 4, 2008 | 09:51 PM
22psi's Avatar
Default RE: piston
Ok so if i am not going to boost it now i dont need to do that
cbr10rr6
Jul 12, 2012 07:59 PM
rodmathews
Aug 5, 2007 10:49 PM
RSM93HONDA
Jul 17, 2007 07:31 PM
95SiR
May 22, 2006 03:45 PM
