piston ring???
Old May 20, 2006 | 10:41 PM
95SiR's Avatar
Default piston ring???
how can you tell, or find out if the rings are gone w/o pulling it out???
Old May 21, 2006 | 12:17 AM
Chiovnidca's Avatar
Default RE: piston ring???
ORIGINAL: 95SiR
A leakdown test may tell you something.
Old May 21, 2006 | 12:34 AM
95SiR's Avatar
leakdown test? hmm i'll look into that, thanks alot
Old May 21, 2006 | 02:34 AM
marbro's Avatar
i would think doing a compression test would tell you because if the rings are going out there would be a lower compression then should be
Old May 21, 2006 | 05:51 AM
deserthonda's Avatar
ORIGINAL: 95SiR
does car smoke kind of blueish smoke out of tailpipe ?? ( burn oil ) ,,, does it use oil ?? do you have to add oil and there are no leaks ?
like it was advised a compression test will do the trick.. do a dry and wet test
dry test is a normal test..
a wet test, put a bit of oil in the cylinder you are testing and record the readings, DO NOT put oil in all cylinders all at the same time. because when you crank it , oil will fly out ,, if compression reading come up considerably , you got worn rings
Old May 22, 2006 | 05:08 AM
marbro's Avatar
ok, my question, with worn rings does compression go down or up? i could understand it going both ways, but I havent had an issue with the rings going out yet, so im not all that sure.
Old May 22, 2006 | 05:45 AM
The pressure would go down or show a lower compression figure than your other stronger cylinders.
Old May 22, 2006 | 10:07 AM
mbo1985's Avatar
Yeah, you would definetly have lower compression than the factory specifications with worn rings.
Old May 22, 2006 | 03:45 PM
marbro's Avatar
hehe, ok, thought so, i guess how desert said it threw me off a little...
Shag Wagon
Oct 23, 2010 10:12 PM
toddyfresh
Aug 21, 2008 07:27 PM
importedminds
Jun 21, 2008 09:24 PM
tfunk
Feb 25, 2007 12:16 AM
Dhorn33
Jan 30, 2007 12:10 PM
