piston ring???
ORIGINAL: 95SiR
how can you tell, or find out if the rings are gone w/o pulling it out???
does car smoke kind of blueish smoke out of tailpipe ?? ( burn oil ) ,,, does it use oil ?? do you have to add oil and there are no leaks ?
like it was advised a compression test will do the trick.. do a dry and wet test
dry test is a normal test..
a wet test, put a bit of oil in the cylinder you are testing and record the readings, DO NOT put oil in all cylinders all at the same time. because when you crank it , oil will fly out ,, if compression reading come up considerably , you got worn rings
ok, my question, with worn rings does compression go down or up? i could understand it going both ways, but I havent had an issue with the rings going out yet, so im not all that sure.
