Polished Valve Cover?
Old Jun 29, 2007 | 12:00 PM
sUbLiMe96's Avatar
Default Polished Valve Cover?
Hey Everyone! Does any1 know whats needed and How I can polish my OEM valve cover to a nice look @ yourself finish?
Old Jun 29, 2007 | 12:15 PM
sir_nasty's Avatar
Default RE: Polished Valve Cover?
High temp paint is typically the most common route. You could always try to remove it and strip the paint so it's just the shiny metal color... Or just buy one
Old Jun 29, 2007 | 03:37 PM
peewee's Avatar
Good aircraft stripper for the old paint to start. The surface underneath should be relatively smooth. Maybe start out with wet 600 grit and work up to 2000. Then use a good aluminum polish to bring the shine out. The key to something like this is patience though...dont rush through any grit of the sanding process or you will have left over scratches that will annoy you to death!
Fuse
Aug 2, 2009 11:05 AM
shadow707
Oct 8, 2008 01:33 PM
03Sleeper
Jun 11, 2008 08:54 PM
mikezz
May 4, 2008 08:45 PM
projectaccord96
Apr 7, 2006 10:14 AM
