problems with key-lock cylinder?
Old Jul 2, 2008 | 10:50 AM
Mr_Accord's Avatar
Default problems with key-lock cylinder?
Hey
I own a 92 Accord LX automatic and I recently have been having problems starting my accord. I put the key in the ignition and the key won't turn to unlock the steering wheel no matter how much a fiddle with the wheel it just won't allow the key to move in and turn to unlock the wheel, is this a problem with my key lock cylinder or ignition switch? And also I checked with Honda and it is really expensive for a new one, can these parts be found used?
Thanks
Old Jul 5, 2008 | 08:43 PM
Chiovnidca's Avatar
Default RE: problems with key-lock cylinder?
Are you using an old, worn key. If yes, try a new one cut from the key code at honda.
Old Jul 11, 2008 | 08:33 PM
mitch4x4
try pushing the steering wheel up some, mine dose the same thing. (if you have tilt. lock it at the very lowest that it will go, then push up then try the key)
Old Jul 11, 2008 | 08:36 PM
Surely trying those fixes cant hurt you..give it the try...
csh217
Jun 17, 2014 05:53 PM
corlyf
Sep 12, 2012 11:30 PM
91accordwagon
Apr 21, 2011 03:29 PM
tulel1
Jan 3, 2011 11:28 PM
wings
Jan 3, 2011 03:18 PM
