rattling noise when accelerating
Old Oct 12, 2008 | 11:41 AM
botang47's Avatar
Default rattling noise when accelerating
well for awhile now, iv noticed that when im accelerating from a stop, theres a rattling sound. this can also happen when im accelerating while driving, but i dont notice it as much.
my car has been leaking transmission fluid from the axle seal for awhile now, but i dont have the money to fix it, so iv just been putting more fluid in. could this be a cause?
Old Oct 12, 2008 | 06:11 PM
Velocifero's Avatar
Default RE: rattling noise when accelerating
ORIGINAL: botang47
Could be, but that leak isn't helping.
Old Oct 13, 2008 | 12:07 PM
ford's Avatar
or maybe it could also be your exhaust pipe falling apart...or maybe its just touching the shield...
Old Oct 13, 2008 | 03:14 PM
botang47's Avatar
but then why would it only rattle when accelerating?
Old Oct 13, 2008 | 04:22 PM
Because when you accelerate, the engine mounts flex, allowing the engine to lean backwards, which causes the exhaust system to flex into a new position.
Old Oct 14, 2008 | 03:19 PM
botang47's Avatar
thanks.
i sure hope its the exhaust and not the transmission
Old Oct 14, 2008 | 04:15 PM
I hope so too, but noises are the hardest thing to diagnose over text messages...
The fact that it changes with throttle suggests that its not valve/lifter noise.
If it were wheel bearings, it SHOULD(?) change with steering around a corner.
Maybe CV joints?
Can you make the noise in an empty parking lot? Have a friend stand outside & maybe tell the location of the sound?
Old Oct 14, 2008 | 04:42 PM
falkore24's Avatar
I've heard that Honda B-pipes have an internal pipe as well that can come loose and rattle.
Old Oct 14, 2008 | 07:20 PM
botang47's Avatar
yeah i had my friend stand outside the car.
you cant hear it when standing over the engine, only when you'reto the side
Old Oct 14, 2008 | 08:47 PM
finch13's Avatar
Crawl under the car (PROPERLY SUPPORTED PLEASE) and check the exhaust pipe end-to-end and make sure the heat shields aren't rattling against the exhaust or floor pan.
