Replace alternator or just brushes?
Old Apr 25, 2007 | 03:56 PM
jtimc7
Default Replace alternator or just brushes?
I have a 1991 Honda Accord that still has the original factory alternator in it (173k miles). The charge light came on and I took it to an auto electric shop today and he simply said it needed a new alternator.
How does one know if all one needs is to replace the brushes or if the alternator really does need to be replaced?
Thanks,
Tim
Old Apr 25, 2007 | 03:57 PM
sir_nasty's Avatar
Default RE: Replace alternator or just brushes?
typically if it's still rotating just fine and not making noise then you can just replace the brushes and it will start charging properly again...
Old Apr 25, 2007 | 05:42 PM
deserthonda's Avatar
First off Welcome to the best Little Honda forum on the net ..
I would do the brushes as well,, Honda sells them ,,, HOLDER+ BRUSHES
part # 31105-PR7-AO1. $ 26.43
Old Apr 25, 2007 | 06:34 PM
incountry's Avatar
i just replaced the brushes on my alternator, only 365,000 miles on the first set
Old Apr 25, 2007 | 06:37 PM
sir_nasty's Avatar
that's it? only 365,000 miles? good lord that's a lot of driving.... what year is your car?
Old Apr 26, 2007 | 01:53 PM
jtimc7
I got the brush holder out...not too hard...The Honda dealers in my areaall say they would have to order this part. Should I wait for them to get one in or would an auto electric shop carry one that is just as good as the Honda one?
Thanks
Old Apr 26, 2007 | 02:30 PM
sir_nasty's Avatar
www.hondapartswarehouse.com
In my opinion those are cheap enough and the job is easy enough to do I'd try the auto electric parts place and if they caused a problem then order the honda ones....unless it doesn't make any difference to you how long it takes to do the job then I'd just go to that link I provided and order them online..
Old Apr 26, 2007 | 03:33 PM
incountry's Avatar
it's a 92 lx 2 dr, that has 387,000 on it now, gonna have to replace the oil pan it finally striped had to go oversize
Old Apr 28, 2007 | 06:40 PM
ORIGINAL: incountry
go to our DIY section there is a write up on how to fix stripped oil pan plugs ..
You DO NOT have to replace the pan
Old May 1, 2007 | 12:27 AM
jtimc7
Do the brushes get any kind of lubricant before they are installed back on the shaft?
Thanks,
Tim
