-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   Rocker very tight against valve? (https://www.hondaaccordforum.com/forum/engine-internal-11/rocker-very-tight-against-valve-64183/)
remix919 Jan 4, 2017 02:46 PM
2 Attachment(s)
I'm having a weird issue with my F23A1 cylinder head, I had disassembled everything to replace a valve and upon re-assembly, I was doing the valve lash adjustments when I noticed that 4 of my intake rockers that sit on the valves are extremely tight against the valve? I had marked timing on the belt and gear so I know TDC is correct on the cam, was wondering if any of you guys had any idea what is causing the tightness? It's just those 4 rockers on the intake side that I circled in red, the other rockers are all fine and I was able to set the valve lash with no issues.
shipo Jan 4, 2017 04:00 PM
When you set the valve lash was the engine really cold?
