Rotor and Distributor
Old Jul 6, 2007 | 06:58 PM
Dazed's Avatar
Default Rotor and Distributor
I hear about replacing spark plug and wires, but what about the rotor and distributor cap?
Are those not big worries? like does it not matter if u replace them or not.
Old Jul 6, 2007 | 07:43 PM
Dazed's Avatar
Default RE: Rotor and Distributor
And wat brands, if any, do you guys recommend? And do they have to match to the plug. Or the rotor and the cap be the same.
Old Jul 6, 2007 | 08:25 PM
BlkCurrantKord's Avatar
Get an OEM cap and rotor.
Old Jul 6, 2007 | 10:57 PM
Dazed's Avatar
could i order those thru Advanced or Auto Zone, or do i have to go thru Honda.
But it shud be ok to only replace Spark and wires?
Old Jul 7, 2007 | 01:58 AM
accord4sroy's Avatar
i but my rotor and cap from autozone at the end of last year and had a shop put those on for $21 or so. but, i think next time i will go with the oem (honda) parts. good luck to you. cap and rotor can last significantly longer now than in the old days. i prefer changing my plugs more often compared to my cap and rotor, but they are definitely important!
Old Jul 7, 2007 | 01:59 AM
i meant bought.
Old Jul 7, 2007 | 07:28 AM
You had a shop do your cap and rotor? Dude all you needed was a philips head screwdriver and 15min max to do it yourself.
Old Jul 7, 2007 | 10:35 PM
Shadow1992's Avatar
Changing your plugs more often? YOu shouldn't even have to worry about those but once every 100k miles, and even then all you need to do is check to see if you get voltage leaks.
Old Jul 8, 2007 | 05:47 PM
Dazed's Avatar
Im goin on 130k miles, and im sure they have never been changed, so why not just change it and be sure.
Plus, hopefully, i will get better gas effiecency(sp).
Old Jul 25, 2007 | 12:18 PM
plugs are something that can affect gas mileage and driveability in my opinion. and, oh yeah my car says to replace the plugs every 30k shadow. yeah, i am lazy BlkCurrantKord so i didn't feel like doing it.
