shaking
Old May 29, 2005 | 10:29 PM
vanessa
Default shaking
i have a 89 honda accord lx-i
well lately the car has been shaking a lot, its seems worse when the car is on but parked, the steering wheel vibrates, it feels really scary!
does anyone know what this may be? and how much it will cost to fix it?
Old May 30, 2005 | 12:36 AM
theycallmerickjames's Avatar
Default RE: shaking
I believe that the shaking is caused bythe motor mounts. Are they are worse when the motor is at a low rpm(when u are stopped) and the gradually go away as u accelerate? If thats the case them i'm sure it's your motor mounts, they become weak over time and the motor begins to shake. Alot of older accords do it. As for the price of repair, I'm really not sure....
Old May 30, 2005 | 01:05 AM
vanessa
Default RE: shaking
yes thats exactly what it does!
i hope its not too spendy
Old May 30, 2005 | 01:39 AM
Default RE: shaking
i'd expect most of the cost to be in labor, being that they will have to lift the motor. The parts, if there are any, shouldn't be that expensive at all. Just look in the phone book and call a few shops to price how much it would be, estimated, to fix your vibrating car.
Old May 30, 2005 | 01:09 PM
jayhova804's Avatar
Default RE: shaking
changing the motor mounts arent too hjard if you have a lift ive help pull the motor out of an 93 accord a few times wanst as hard as i thought it would be
Old May 31, 2005 | 07:12 PM
Alekat's Avatar
Default RE: shaking
Don't rule out a bad spark plug/wire or injector?
Old May 31, 2005 | 07:14 PM
Alekat's Avatar
Default RE: shaking
A
Old Jun 3, 2005 | 03:06 PM
Gummi_67's Avatar
Default RE: shaking
I'd say motor mounts as well. Or maybe a really low idle...?
Old Jun 5, 2005 | 12:09 AM
vanessa
Default RE: shaking
ugh i really feel so stupid. My dad came by and checked it out, there was some wire or somethin that wasnt in the right place, now it fine, no shaking
BUT now im having problems withe something else, my car overheated around the same time i posted this, i had the oil changed, water was put in, as well as antifreeze, it was fine until yesterday, my temperature gauge started going up and down, it went straight to H while stopped at a red light, and a little smoke would come out from the hood, then as i accelerated, it would go back to normal.
Anyone know what this is?
lol maybe i just need a new car![]
Old Jun 5, 2005 | 12:55 AM
Alekat's Avatar
Default RE: shaking
What color smoke? Usually - White is coolant - Black is excessive fuel - Blue is oil
Also - Water pump belt tension loose.
Air in cooling system. Remove radiator cap when cold and top off if low, (50/50 mix).
