short ram intake?
Old Nov 17, 2008 | 10:34 PM
jamesh23's Avatar
Default short ram intake?
I have $40 and cant order off or ebay for reasons that are complicated, Could i make one out of these parts?
2.5" silicone coupler
3" 90 degree bend
3" base filter
and how would I attach it to my 1988 honda accord LXi its fuel injected,.
Old Nov 17, 2008 | 11:36 PM
Default RE: short ram intake?
the only way to know for sure is to go out and try and piece it together.
Old Nov 18, 2008 | 07:51 AM
falkore24's Avatar
you need a few feet of straight pipe and PVC sealer. Trichloromethane works best, but you could also use rubber cement.
Old Nov 18, 2008 | 08:25 AM
jamesh23's Avatar
ok well thank you to both of you guys. I need a few feet of pipe for a cold air intake or a short ram intake? and I just hook it up to the old intake right? But do I just throw away the old intake or save it?
Old Nov 18, 2008 | 08:45 AM
falkore24's Avatar
save it in case your intake leaks or you want to go back. Either intake will require straight pipe.
Old Nov 18, 2008 | 06:40 PM
jamesh23's Avatar
Could I make a cold air intake out of those parts plus some feet of pipe?
Im going to use 2.5 inch diameter pipe, how many feet should I buy? I cant cut it myself though just so you know, i need to know before 7 cuz that is when they close, thanks.
Old Nov 19, 2008 | 08:12 AM
falkore24's Avatar
If you don't have one, buy a hacksaw. Then you can cut it yourself. Also, get the thin kind of PVC pipe. No need for the heavy stuff.
Old Nov 19, 2008 | 08:29 AM
jamesh23's Avatar
alright so in total I need
hacksaw
2.5" pvc pipe like 5 feet?
2.5" 90 degree bend?
3" cone filter
pvc sealer or rubber cement.
Old Nov 19, 2008 | 11:28 AM
falkore24's Avatar
If you have 2.5" pipe, you could use a 2.5" filter. 5 feet should be about right for a CAI .... better to get an extra foot if that's what you are going to build, so 6 feet total.
Old Nov 19, 2008 | 06:21 PM
jamesh23's Avatar
what kind of degree bends should I get? and how many of each? do i need any zipties and stuff?
