Spudder then Sudden Acceleration
Old Mar 4, 2021 | 08:27 PM
Matts99's Avatar
Default Spudder then Sudden Acceleration
'99 Accord LX, manual 5 spd, 4 cyl.
Warm engine, cruising 45mph (ish), car starts to spudder, speed drops, give it gas, rpms go up, then sudden acceleration.....repeat.
Replaced distibutor, spark plugs and wires. Not sure if my guy checked catalytic converter. Any ideas?
Old Mar 5, 2021 | 12:56 PM
Has it just started happening? Has it been going on long enough to rule out a bad tank of fuel?
Was any work done on the car just before this? (I assume the plugs etc were done after this started)
What kind of spark plugs & wires?
Old Mar 7, 2021 | 09:53 AM
Matts99's Avatar
Started out of the blue. I got 02 sensor code. I changed upstream 02 sensor. Plugs,wires,dist. were post spudder. Bad fuel was a thought.
Old Mar 8, 2021 | 04:01 PM
There's several error codes for the O2 sensors. Which code # did it show?
Did it start happening right after getting fuel?
Old Mar 11, 2021 | 03:07 PM
Matts99's Avatar
Jim, I do not recall the code number. The code had list of possible remedies, the first of which was 02 sensor. I ran 1/2 tank of fuel when it started. Kinda ruling out fuel for now. I may try fuel treatment to clean injectors.
Old Mar 11, 2021 | 07:37 PM
I was trying to learn if the codes pointed to the front vs. rear O2 sensor. But most likely the rear O2 sensor doesn't have much (if any) authority over fuel.
Re-reading post #3, now I wonder if it all started after replacing the O2 sensor? What brand of sensor? I've heard a few stories of Honda engines not getting along with Bosch O2 sensors. The OEM sensor is Denso.
Old Mar 18, 2021 | 06:10 AM
Matts99's Avatar
Hey Jim, I replaced o2 sensor with an off brand, got a dense on the way. I will keep you posted.
Old Mar 27, 2021 | 09:03 PM
drewusmaximus's Avatar
Sounds like the fuel pump.
Old Apr 3, 2021 | 10:36 PM
Matts99's Avatar
I installed a new denso o2 sensor. I gave it a nice long test drive and everything appears to be working fine.
Old Apr 3, 2021 | 10:37 PM
Matts99's Avatar
Thanks for the help, Jim.
Cristos98
Oct 4, 2011 01:05 PM
alr5022
Jan 28, 2009 11:11 AM
gtg162y
Jan 2, 2009 10:55 AM
eichhoma
Dec 16, 2008 09:18 AM
indy49
May 18, 2007 06:44 PM
