a strange idea.
Old Feb 26, 2012 | 03:00 PM
g22cd5's Avatar
Supper Moderator
I don’t see how you got thos numbers??? Plz explain…
ok now I did this set up for ya…
f23 block
f22 head
h22 crank
h22 rods
h22a JDM pistons
you come out with
10.94:1 c/r
with -0.006 out of the hole (which is fine)
with 1.58:1 rod stroke ratio
Now if you want to factor in the k20 pistons you will need to know the dome (cc) for the k20 piston your using as well as the compression height (mm)
the wrist pin comes into play at this point. It can change the c/r depending on the location.
Old Feb 26, 2012 | 08:15 PM
Jap.Doe's Avatar
the calculator says
h22 block
f22 crank
f22 head
h22a pistons
h22 rod
14.87 c/r and .079 out :/
well im trying to do something with an h22 block cause my buddys selling an entire block for 200. he has the head as well but i wanna do a sohc non vtec build :P
i cant find the dome cc for the k20 though :s
Old Feb 26, 2012 | 08:25 PM
Jap.Doe's Avatar
okay how bout this
h22 block
f22 crank
f22 rods
h23 pistons
11.5:1 c/r eh?
thunder_x
Nov 1, 2006 07:05 PM
thunder_x
Sep 27, 2006 11:00 PM
poff1986
Aug 2, 2006 03:43 PM
joshuaaaronalpert
Dec 30, 2005 03:40 PM
LiLLita361
May 4, 2005 02:16 AM
