is there a benefit to placing this mod?
Old Mar 29, 2008 | 11:51 AM
HORSEPOWERJUNKIE2007's Avatar
Default is there a benefit to placing this mod?
do you guys think it'll be a good gain for this mod?here's the description of the item
[*]97 - 01 HONDA PRELUDE Si TYPE-SH 2.2L DOHC 16V VTEC H22A4 [/ul]
This package includes:
[*]4 pistons with pins & clips.[*]1 complete piston ring set for all 4 pistons.[/ul]
and i have a F23A5..would that help me in any types of gains in horsepower or torque or anything for that matter...
Old Mar 29, 2008 | 01:30 PM
sir_nasty's Avatar
Default RE: is there a benefit to placing this mod?
From your description it's a set of pistons.... they won't fit.... the f23a5 is a 2.3L engine and the H22A4 is a 2.2L so chances are your pistons are already bigger (diameter wise) than the ones you listed....
Old Mar 29, 2008 | 02:12 PM
BlkCurrantKord's Avatar
^Nope
The H22 is 87mm bore, the F23 is 86mm bore. You shouldn't go beyond a .5mm bore on stock sleeves. Also, you'd need a complete rebuild of the entire bottom end.
Old Mar 31, 2008 | 12:27 PM
Well what if i just swapped my F23A5 cylinder heads for the F23A1...would there be any difference in performance...because right now my F23A5 is suppose to give me 135HP while the F23A1 gives off 150Hp...so do you guys think it would be worth swapping my cylinder heads..
Old Mar 31, 2008 | 05:04 PM
00AccordLX5spd's Avatar
Registered User
No. You would have to get an ECU from an F23A1. Entirely too much money and work to do for a lousy 15 extra hp
Barry92LX
Jan 27, 2010 09:27 AM
ryanmunce
May 29, 2007 06:42 PM
DrumProdigy83
Apr 23, 2005 02:00 AM
