Timing Belt / Acessory belts
I bought a 93 accord 10th aniversary edition.
I am about to do a timing belt, I am not sure what the previous owner has done when it comes to maitenance. Here is what I have bought all OEM stuff. All belts, Air filter valve cover gasket, oil pan gasket, fuel filter, air filter, all plugs, wire set, distributor rotor, cap , gasket and O ring. Thermostat, gasket, Oil drain plug, oil filler cap, new interstate Battery, PCV valve and gromet, engine torque rod, transmission fluid, all hoses, all seals , water pump, both tensioners, hood release cable, complete front suspension ( control arms etc ) Oil filter, Also I will adjust the valves, already replaced the Fast idle valve and hoses, Brake pads, front and rear . I have spent $500 in all parts, I have bouthg parts from all over the country, the only thing I bought at the stealership were the belts ( timing belt and balancer shaft belt )I will do the job myself. I have done my civic's engine , entirelly, Piston rings, timing belts , water pumpetc etc. Ater everything is done I will have spent a total of $2500 including the price I paid for the car. What else am I missing ? Any hints adivse or tips will be greatly appreciated. Thank you. The car has 137K miles Auto |
RE: Timing Belt / Acessory belts
rotors or drums? power steerng fluid to flush the system? anti-freeze? brake fluid to flush the system?
