Timing Belt / Acessory belts
Old May 2, 2007 | 12:23 AM
mig25's Avatar
Default Timing Belt / Acessory belts
I bought a 93 accord 10th aniversary edition.
I am about to do a timing belt, I am not sure what the previous owner has done when it comes to maitenance.
Here is what I have bought all OEM stuff.
All belts,
Air filter
valve cover gasket, oil pan gasket, fuel filter, air filter, all plugs, wire set, distributor rotor, cap , gasket and O ring.
Thermostat, gasket, Oil drain plug, oil filler cap, new interstate Battery, PCV valve and gromet, engine torque rod, transmission fluid,
all hoses, all seals , water pump, both tensioners, hood release cable, complete front suspension ( control arms etc )
Oil filter, Also I will adjust the valves, already replaced the Fast idle valve and hoses,
Brake pads, front and rear .
I have spent $500 in all parts, I have bouthg parts from all over the country, the only thing I bought at the stealership were the belts ( timing belt and balancer shaft belt )I will do the job myself. I have done my civic's engine , entirelly, Piston rings, timing belts , water pumpetc etc.
Ater everything is done I will have spent a total of $2500 including the price I paid for the car.
What else am I missing ? Any hints adivse or tips will be greatly appreciated. Thank you.
The car has 137K miles Auto
Old May 2, 2007 | 03:52 AM
jombolo's Avatar
Default RE: Timing Belt / Acessory belts
rotors or drums? power steerng fluid to flush the system? anti-freeze? brake fluid to flush the system?
5.0stang
Apr 23, 2013 06:37 PM
mugenpaolo
Apr 13, 2009 09:34 PM
95 Honda Gem
Jun 1, 2008 04:09 PM
Tony1M
Apr 1, 2007 05:42 PM
quietgiant
Jan 30, 2007 01:37 AM
