K series swap into 6th gen
Old Apr 28, 2007 | 03:45 PM
Altrdillusion
Default K series swap into 6th gen
Whats up everyone. New to the forum and have a question. It has probably been discussed but how hard would it be to swap a k series motor into a 6th gen with an I4? I know a h series swap would be easiest but that swap is played out. I also want to swap in a 6spd from the RSX-S. Ive heard of the TL 6spd swap into the v6 which I will be doing to my other accord but I want the room for a turbo. Any ideas? Ive seen pics of the swap into a 5th gen but not into a 6th. I also heard that the euro spec accords come stock with the k24? How true is this info?
Old Apr 28, 2007 | 03:49 PM
otsb708's Avatar
Almost A Senior Member
Default RE: K series swap into 6th gen
If they can swap a k24 motor into an FIT then I am pretty sure that the same motor will fit into the accord. It is just a matter of finding someone to make all the motor mounts,tranny mounts, etc......let alone buying the motor and computer and all that good stuff, it is going to cost a pretty penny, but it definitely will be worth it in the long run........
Old Apr 28, 2007 | 09:11 PM
03Sleeper's Avatar
I would wait a bit....k engines are starting to attract attention. you'll probably get better/more options as time passes by.
Old Apr 30, 2007 | 02:16 AM
YeuEmMaiMai's Avatar
engine is turned around compared to the F series so that will mean using V6 accessories if you want it to work with minimal trouble. Getting the 5spd auto to work will be a pita
Old Apr 30, 2007 | 09:28 PM
Chiovnidca's Avatar
He would have to use a k-series transmission. 5 or 6 speed manuals are readily available. A buddy of mine did the swap into his civic.
Old May 2, 2007 | 10:30 AM
Altrdillusion
I appreciate the info. I may just turbo the f23. I am not looking to race it just make it a blast to drive.
6thGENvtec
Oct 14, 2012 07:12 AM
g22cd5
Jul 30, 2009 07:15 PM
finch13
Apr 15, 2008 10:13 AM
BuntinBoy9
Nov 11, 2007 06:56 PM
vtechex
Jul 27, 2007 07:57 AM
