Timing belt: Dealer vs Shop?
I have a 2000 Honda Accord, 4 cylinder with 73K miles and time to get the timing belt/water pump replaced.
Now the question is where should I get them done? I am not a car techie and have always been riped off from local honda dealers. Went to 4 different dealers and all are the same -- bad work and rip you off. Both dealer and other shops charge similar amount; so cost is not in the equation. For a major job like timing belt, should I trust a local shop? or I should still go to the worthless dealers? |
RE: Timing belt: Dealer vs Shop?
I'd let the dealer handle that one unless you are 100% sure that the said shop is competent at working on hondas and uses honda oem parts.
Do you live in tempe az.
1st option see if you can find a shop the SPECIALIZES on Hondas ,, they will use factory parts and it would be cheaper than the dealer
2nd option the DEALER WHERE DO YOU LIVE ?? |
