Timing belt: Dealer vs Shop?
Old Aug 24, 2006 | 04:45 PM
az85249
Default Timing belt: Dealer vs Shop?
I have a 2000 Honda Accord, 4 cylinder with 73K miles and time to get the timing belt/water pump replaced.
Now the question is where should I get them done?
I am not a car techie and have always been riped off from local honda dealers. Went to 4 different dealers and all are the same -- bad work and rip you off.
Both dealer and other shops charge similar amount; so cost is not in the equation.
For a major job like timing belt, should I trust a local shop? or I should still go to the worthless dealers?
Old Aug 29, 2006 | 08:43 AM
YeuEmMaiMai's Avatar
Default RE: Timing belt: Dealer vs Shop?
I'd let the dealer handle that one unless you are 100% sure that the said shop is competent at working on hondas and uses honda oem parts.
Old Aug 29, 2006 | 12:15 PM
Do you live in tempe az.
Old Aug 29, 2006 | 12:19 PM
deserthonda's Avatar
1st option see if you can find a shop the SPECIALIZES on Hondas ,, they will use factory parts and it would be cheaper than the dealer
2nd option the DEALER
WHERE DO YOU LIVE ??
handsomerob
Jun 6, 2013 03:54 PM
mtrmouthb
Jul 10, 2008 08:41 AM
humblehyper
Apr 16, 2008 05:41 PM
Tony1M
Apr 1, 2007 05:42 PM
