tranny issue?
when im on the freeway, and have it floored, it does good til we 5th gear....at the end of 4th, it does 6200 rpms and keeps backing down and wont go into 5th unless u cruise into it half-throttled or so...i was curious wat this meant...i just built an intake for it last thursday and have many more plans to come. oh, its a 95' accord. automatic... i was also thinking about having it converted into a manual but am not sure how to go about that. some advice is highly appreciated =) THX
RE: tranny issue?
The 95 Accord auto has a 5spd tranny? Thought they didn't have 5spd auto accord tranny until 2003.
RE: tranny issue?
u know what..ur right lol. i miss counted =) its a 4 speed =P so ya, entering 4th gear is my prob ...
RE: tranny issue?
when was the last time you had any service work done to the tranny? I.E. fluid change...
RE: tranny issue?
never had service done. got it from dealer down the street. maybe i should do a tranny flush??? and is full synthetic tranny fluid better?
RE: tranny issue?
don't do an actuall forced flush, you just want to drain and refill it. I'd suggest using Honda ATF. Ask the dealer if they ever did it, you could also have them pull the dipstick and tell you what they think of the quality of your current fluid. Even if this doesn't fix your issue it's a basic matainence item that should be done if it hasn't been done recently
RE: tranny issue?
If you're flooring it don't expect it to pop into 4th gear until 100-105 mph and that's after it dips from redline to ~5800rpm and back.
RE: tranny issue?
mabey while were on this subject ill bring up my girlfriend 96 Honda accord. When ever im driving it, it will be going fine then every once in awhile it will rev high then shift, without flooring it. And it rarely happens....Time to change fluid?
RE: tranny issue?
time to get the transmission diagnosed
RE: tranny issue?
ORIGINAL: finch13 If you're flooring it don't expect it to pop into 4th gear until 100-105 mph and that's after it dips from redline to ~5800rpm and back. |
