transmission
Old May 12, 2007 | 08:16 PM
smaglik's Avatar
Default RE: transmission
Sequential
Manual
Gearbox
Paddle shifters, but using an actual manual gearbox, not the bs autostick you find in a lot of cars (which is an automatic). The e46 generation of M3's (01-06) has an available one (it was first released in the e36 generation), and it uses the exact same getrag 6-sp manual gearbox, but uses clutches and actuators to do the shifting. It is pretty cool, as it shifts amazingly quickly. Jerks you back and forth pretty good.
Old May 12, 2007 | 08:31 PM
poser_pilot6
Ah, gotcha. Thanks brotha.
Old May 12, 2007 | 09:55 PM
smaglik's Avatar
np...the next advancement for the new generation is a dual clutch gearbox, so it shifts f1 style, but since there are two separate clutches, the power is never disengaged...i.e. no jerkin...i like jerkin.
Old May 13, 2007 | 07:10 PM
hondawisher's Avatar
wow learning alot here,thanks smaglik. Hey up is there one of those transmissions out for honda accords yet?
Old May 13, 2007 | 08:09 PM
smaglik's Avatar
No, though they did do an autostick type thing with the last generation of preludes. Other members on here are better in tune with what's coming donw the pipe from them. I would expect it to be in the S2000, if anything.
Old May 16, 2007 | 12:58 AM
YeuEmMaiMai's Avatar
I'll make this as simple as possible. within each generation, the slowest V6 model is still faster than the fastest I4 accord (auto or manual)
Old May 16, 2007 | 07:58 AM
  #17
smaglik's Avatar
Slowest V6 model...are you talking across the entire product line, or within model? Which model had more than one V6 offered?
Old May 17, 2007 | 07:25 PM
  #18
hmm interesting, ok umm how do you go about making an automatic transmission for a honda accord, shift faster?
Old May 17, 2007 | 10:59 PM
  #19
03Sleeper's Avatar
Duuuude...they need to make SMG for the V6 Accord then.
Old May 18, 2007 | 06:32 PM
  #20
sir_nasty's Avatar
ORIGINAL: hondawisher
Custom ECU chip to change the shift points and shift style...
