turbo need help
Old Jun 17, 2008 | 09:17 PM
mack29730's Avatar
Default turbo need help
ok i have researched and have one question before i go any further which is better to turbo f22a or f22b?
Old Jun 18, 2008 | 09:53 AM
Flatline1121's Avatar
Default RE: turbo need help
I have been looking at the same thing and i think the F22A (luckily the on i have) is better b/c it is non-vtec which is better for more boost. or so i have been told by others on here. but you could always convert the F22B. Right?
Old Jun 18, 2008 | 10:09 AM
ORIGINAL: Flatline1121
depends on what f22b it is, b1 is vtec b2 isnt, and just straight up f22b is dohc non-vtec
Old Jun 18, 2008 | 10:50 PM
HMMM.... So is that the only differencebetween the two?
Old Jun 19, 2008 | 04:24 PM
mack29730's Avatar
i have the stright up f22b non v-tec and i have a f22a that already has ported and polished head i was trying to find out which is better to turbo the a is single over head cam and the b is double
Old Jun 20, 2008 | 02:17 PM
KevinAccord's Avatar
i think the double gives you more compression on NA, but if you wanna turbo you have to lower compression by changing to low pistons and then boost it to get a nice compression.(uh?) i know it sound like your taking something to put some other stuff which will do the same thing but that's how it works... get the dohc
Old Jun 20, 2008 | 03:20 PM
BlkCurrantKord's Avatar
How woud a DOHC head give him more compression? That doesnt even make sense.
Old Jun 20, 2008 | 03:33 PM
Compare compressions:
F22B
Specifications
[ul][*]Bore × Stroke: 85.0 × 95.0 mm[*]Displacement: 2156 cc[*]Valve Configuration: DOHC, 16 valves[*]Compression ratio: 9.3:1[*]Max power: 166 hp (119 kW) @ 6000 rpm[*]Max torque: 150 ft·lbf (200 N m) @ 5000 rpm [/ul]
F22B1
Specifications
[ul][*]Bore × Stroke: 85.0 × 95.0 mm[*]Displacement: 2156 cc[*]Valve Configuration: SOHC, 16 valves, VTEC[*]Compression ratio: 8.8:1[*]Max power: 145 hp (108 kW) @ 5500 rpm[*]Max torque: 147 ft·lbf (199 N m) @ 4500 rpm [/ul]
Old Jun 20, 2008 | 05:30 PM
Alot more goes into calculating compression than what you have listed.
Old Jun 23, 2008 | 09:39 AM
falkore24's Avatar
BCK: I think that Kevin is saying that the OP gets a higher compression stock with the DOHC motor, not that the head configuration creates the higher compression.
