Vtec Block
Hey i own a 94 accord sedan thats a five speed. it is a non-vtec engine f22b2. i was wondering if i could make it vtec by dropping a top vtec block on the top of it. yes??? no???? i have heard both. thanx
RE: Vtec Block
Hmmm. Well if you drop an engine block on your engine, you will likely break things. However, if you mean "can I put a vtec cylinder head on my non-vtec F22B2 and make it a vtec?" then the short answer is yes. But you will need the head and everything it entails, along with some (if not all) of the wiring from the vtec engine, and most likely the ecu out of the vtec car as well. But it can be done!
RE: Vtec Block
u need to basicly get everything but the block out of a Vtec engine swap...
RE: Vtec Block
i Rather just get a new engine then doing all that stuff. Myabe a h22 or if you wanna stick with f seris engine then f23A1
RE: Vtec Block
h22 head on a f23 is better than a h22 all around... h22 bottom end sucks...
| All times are GMT -5. The time now is 10:31 AM. |
