weird wining noise, help!
Old Jun 25, 2007 | 05:55 PM
noboundaries6289's Avatar
Default weird wining noise, help!
hey all, I just got some parts replaced as I mentioned in past post. IE: belts, water pump, and seals. When I got it back from the mechanic, I noticed a weird wining noise. No matter what RPM i'm at i still hear it. I called the mechanic and he said it was just the new parts breaking in. Is this true or is it something to worry about?
PS: just switched to Mobile 1 synthetic, Woohoo!
In case you didn't read my past post, i replaced,
BAL SHAFT SEAL
BAL SHAFT SEAL RETAINER
OIL DRIVE GEAR SEAL
FRONT MAIN (CRANK) SEAL
CAM SEAL
VALVE COVER GASKET
SPARK PLUG TUBE SEALS X 4
TIMING BELT
BALANCE SHAFT BELT
WATER PUMP
Old Jun 25, 2007 | 06:14 PM
sir_nasty's Avatar
Default RE: weird wining noise, help!
Can you tell where it's coming from? It sounds like the water pump might be whining but I can't say for certain.... I have a hard time believing that it's just the parts breaking in..... See if you can pinpoint the noise.... has it been going on since you got the car back? If your waterpump goes out and breaks the timing belt is he going to fix it under warranty?
Old Jun 25, 2007 | 06:35 PM
it sounds like it's comming from the center of the engine. But I can't be sure. I'll take it up there tommorrow before work to let him listen to it.
Old Jun 25, 2007 | 06:45 PM
tkundert2's Avatar
Sometimes you can pinpoint the location by putting a stick to your ear and touching various parts of the engine. Be careful around rotating pulleys, belts, etc.
Old Jun 25, 2007 | 06:47 PM
sir_nasty's Avatar
The most common place I've heard of that squeek coming from after a repair was the tensioner.... Someone else in here had the same issue a month or so ago....
Old Jun 25, 2007 | 07:30 PM
im gonna wake up at 7:45 to get there at 8:00. I'll give them 2 hrs. to work on it. I guess i'll just play it by ear. Some people told me a water pump bearring could be too tight or a pully out of alignment. idk.
Old Jun 25, 2007 | 07:52 PM
I made a movie on it, it's 3.7mb. You can sort of hear the noise.
http://newnoboundaries.com/MVI_0751.avi
Old Jun 28, 2007 | 10:18 PM
I went and he said the timing belt was just tight. He said it should loosen up and quiet down in a couple of hundred of miles. If the sounds not better by next week, he said he'll go into the engine and check everything out again. So far I put 100 miles on the new parts and I still hear the whining. I found another oil leak, the disty O-ring. they replaced it for me though. I hope that was the solution to my leaky engine.
Old Jul 16, 2007 | 04:46 PM
jimbrown618's Avatar
Just so you know, I had the same problem with my 96 Accord after TB replacement. Turns out the tech put too much tension on the belt. Had it properly adjusted by a Honda trained tech.
Noise gone. All is well.....
Jim
Old Jul 16, 2007 | 10:14 PM
smaglik's Avatar
sounds like you may need to make him re-adjust....
