what could lower mileage on f22b5 accord coupe ES ?
Old Apr 23, 2007 | 11:42 AM
00AccordLX5spd's Avatar
Registered User
Default RE: what could lower mileage on f22b5 accord coupe ES ?
Could it possibly be clogged fuel injectors? Have you run a fuel system cleaner through the car yet?
Old Apr 23, 2007 | 03:39 PM
miks's Avatar
im not sure i get what you meant. how can i do that?
Old Apr 23, 2007 | 06:19 PM
He means a fuel-injector cleaner (solvent)that you pour into the gas tank. Chevron Techron, or several other brands here in USA. I don't know what's available over in Latvia.
Old Apr 23, 2007 | 06:35 PM
Registered User
Or something like seafoam. You pour it in the throttle body throat, the gas tank, and oil crank case.
Here's a link: http://www.seafoamsales.com/motorTuneUpTechGas.htm
Old Apr 23, 2007 | 06:45 PM
marbro's Avatar
miks, i dont know how much you will be able to improve it.... Was it you that said your car was 150hp? If it is that means your car is just dumping more fuel into it in general after all it doesnt have vtec for the whole gas economy, granted yeah it shouldnt be as bad as 13mpg but it is in city with a more agressive cam so I can understand why it would be that bad, Have you driven a full tank highway at about 120kph?
Old Apr 24, 2007 | 04:10 AM
miks's Avatar
yea my car is 150hp non-vtec, but its mileage should be ~18-19MPG in city (one friend has the same engine on wagon chasis).
mileage is bad also on highway 23MPG at 60mph cruising (it should be more like 28-30).
ill try that cleaner.
although i already emailed the dealer for a full engine diagnostic posibilities.
how about all those air meters, o2 sensors and lambda zondes?
Old Apr 24, 2007 | 11:10 AM
  #17
marbro's Avatar
Well, if thats what all the information says your mpg/kpl should be then ignore what i said, as for the o2 sensors, those being defective could cause that drop, but those are also not cheap and you should resort to replacing those when youre absolutely sure they are bad.
Old Apr 24, 2007 | 12:51 PM
  #18
miks's Avatar
i checked the repair manual for O2 sensor response monitoring. ill do that when ill be able to get under the car for connection.
i already checked the cost of it, ~150$ at dealer, 50-100$ on ebay. pritty high pay for such a little ****
hondagrl
Jan 23, 2022 02:16 PM
hotsauce61488
Sep 21, 2012 07:51 AM
wrencredle
Jun 27, 2012 08:38 PM
annarborcoupe
Dec 16, 2010 07:25 PM
klo
Jul 16, 2008 10:15 PM
