when accelerating, high pitched sound
Old Jan 4, 2007 | 11:56 PM
asphyxxed's Avatar
Default when accelerating, high pitched sound
when accelerating...or when i push the pedal to a certain point i start to hear a very high pitched sound...any ideas of what it can be coming from or whats wrong? kinda gets to my head sometimes...
Old Jan 5, 2007 | 01:15 AM
legionofone's Avatar
Default RE: when accelerating, high pitched sound
try it again with the AC on... some cars disable the AC compressor (throw the clutch in) when accelerating quickly... it might be the bearings in the compressor hurting...
Old Jan 5, 2007 | 02:26 AM
deserthonda's Avatar
could be the alternator,, Honda had a few issues with v6 alternator ( delphi made ) junk......
start engine. have a friend rev it up till it makes the noise, get a long screrwdriver and put it on places where you think the noise is coming from and the handle on your hear,this will help pin point where the noise is from
, MAKE SURE NOT TO STICK IT IN ANY ROTATING PARTS .....
Old Jan 9, 2007 | 12:34 AM
LaminatedKitten's Avatar
i had a similar problem, your throttle is probably 1/8-1/4 of the way down and it stops if you let off or push harder? almost a vacuum related issue, although i can't seem to remember how i fixed mine, i just remember realizing it stopped
Old Jan 9, 2007 | 12:38 AM
asphyxxed's Avatar
yeah exactly...gets pretty annoying when you wanna go a steady speed but you dont wanna hear that damn sound so you just either push harder or let off and it stops...thats exactly what is happening...if anyone can help id really appreciate it...thanks for better explaining it
Old Jan 9, 2007 | 06:42 PM
sir_nasty's Avatar
do like desert said and try to pinpoint where it is coming from.... It may also just be a loose or worn belt.... get it to a position where you can hear the noise and try to find it, if you can't then turn the car off and check to see if the belt is cracked/worn/glazed and/or loose, if it's bad replace it, if it's loose just tighten it and that may solve your issue too.
pbplayer257
Jul 13, 2010 02:31 PM
Randy367
Mar 30, 2008 07:24 PM
dmullen
Oct 9, 2007 03:10 PM
elbarto83
Oct 3, 2007 07:01 PM
FlyLow
May 15, 2006 08:57 PM
